Revit MEP Forum
Downgrading file type
2 REPLIES 2
chrishawkins12
642 Views, 2 Replies
I am working o a project that the architects are putting everything together using Revit 2012 and I upgraded my file to Revit 2013. How do I take a step backwards and bring the MEP file to 2012? Any info is much appreciated!
-Chris
2 REPLIES 2
abulla
in reply to: chrishawkins12
I'm afraid I have bad news. You're going to have to find a backup file somewhere, you can't roll back to previous versions.
CoreyDaun
Hi Chris, welcome to the Discussion Groups!
Unfortunately, Revit is NOT backwards compatible; once a file has been created in or upgraded to a newer version of Revit, it cannot be saved back to a previous version.
The best you can do it export your 2013 file as an IFC file and them import that file into a new 2012 Project. But this will yield little more than a static, model object that will retain very little (if any) of the information that it once held.
Rail Community
