Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Display path hot and cold water
2 REPLIES 2
GHASEM_ARIYANI
397 Views, 2 Replies
hi
Usually drawings piping Hot and cold water paths sweep Use the arrow Show.
For example,
Hot water> red arrows continuous
Cold water> blue arrows continuous
Is this possible in Revit MEP automatically?
Please guide
Thank you
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
Revit has no ability to create true flow arrows. You would have to create a Generic Annotation family and manually apply it. There may be other suggestions out there - just search this forum with terms like "Flow Arrow" and see if you can find any useful information.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi
Thank you very much your answer.
Yes, I've used this method.
But I thought maybe there is a better way.
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Complex_(Text)_Line_Type
