I have been having a problem with walls vanishing. As the attached JPEG shows, the zoomed out version (top) does not show a wall, but a zoomed in version (bottom) does. Is there any explanation for this? This is happening on many walls. I never had this problem with the 2010 software. Thoughts? Thanks.
-Tim
Solved by jason.martin. Go to Solution.
Hi Tim -
My first step would be to try turning off hardware acceleration and see if that helps (R -> Options -> Graphics Tab). You'll need to close and re-start Revit for the setting to apply. If that clears up the issue please post back with your graphics card and driver version.
hth
jason
Hello, I am having the same issue as described above. I used the same advice and turned off hardware accelation. Upon reopening the file, the problem still exists. I will also add that I can make the walls reappear if I pan, and similarly if I zoom all the way out.
I found a solution... If you toggle "wireframe" to "shaded" to "hidden line (the graphic display in which I was originally in)", it regenerates the model. All walls, views, and prints are fixed. I think it would be great to have a regeneration of model option in Revit sort of like CAD.
The problem was within Revit. We opened it on two different computers and my above solution resolved it both times. I appreciate the response!
