Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Dimension to control elevation placement and report in a schedule
3 REPLIES 3
LisaDrago
312 Views, 3 Replies
Hello - I am working with a client and we need to place a component that we can control the elevation and have it show up in a schedule. I know we can do this (or at least i think we can) but I cannot make it work. Is this possible?
what am i missing?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
3 REPLIES 3
CoreyDaun
in reply to: LisaDrago
Really, you're not missing anything. One cannot Tag or Schedule the elevation of vertically-hosted families - that parameter is inaccessible. A search of this forum should yield a couple of work-arounds or alternate possibilities that were mentioned in the recent past.
The most basic solution is to create a Shared Parameter, but then it must be manually controlled.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
LisaDrago
Thank you for the reply.  I will see what the other posts mention.
LD
dennis
http://appliedsoftwareblog.blogspot.com/2012/02/accessing-non-assessible-parameter-data.html
The link above tells about 'a way' to get access to the Elevation data via some nifty programming that is free to download.  I particularly like this addin cuz of the cat logo.
