Ok, so I have a dependent view in which near the matchline I have a gridline. The grid line is in the model and not linked. However, no matter what I do, I can not dimension to this gridline. All other ones are fine. Is this something to do with the annotation crop or something? I tried moving it and the crop region a little bit, neither one seems to help. What gives? Thanks so much for your help!
Solved by revitworkbench. Go to Solution.
