Hello everyone,
Is it possible to create two room areas in the same place ? I´m using a plugin for lighting calculations and this plugin use the room area. The question that we are facing is that the room area defined by the Architeture team is diferent from the one needed for the lighting calculation. Is that possible to create two superimposed room areas?
Joao Laudares
Solved by CoreyDaun. Go to Solution.
It uses the Rooms and not the Spaces? If so, then the only way to have Rooms occupy the same physical location (that I know of) is to employ Design Options, and place the normal Rooms (and Room Seperators) on "Option 1 (primary)" and the calculation Rooms on "Option 2".
