Revit MEP Forum
different colors in a single tag?
1 REPLY 1
revitworkbench
363 Views, 1 Reply
Ok, so i have some very complicated tags. I was wondering if there was a way to make certain text in the tag one color, and other text in the same tag a different color to help the reader snap his eye to the information in the tag that he is looking for. Is this possible? if so how! Thanks!
1 REPLY 1
CoreyDaun
in reply to: revitworkbench
The Label elements themselves can be assigned different colors. This can be done by creating a duplicate Label Type and assigning a color to it. (Select the Label, go to Type Properties, click "Duplicate...", and define the color.)
You cannot, however, assign differing colors to specific text WITHIN the same Label element.
