Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Darker Lines for Linked Models
6 REPLIES 6
8008 Views, 6 Replies
Hi everyone
I've printed out a couple of mechanical drawings, with a linked architectural model, and the linked model's lines are appearing too light. Is there a way to make the architectural model's lines appear darker? I'm printing to PDF, then to a KIP 3100 printer, if any of that helps.
Any help with this would be greatly appreciated.
6 REPLIES 6
Martin__Schmid
Have you tried:  Manage tab > Settings panel > Additional Settings > Halftone / Underlay and moving the 'Brightness' closer to 'Dark'?
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
in reply to: Martin__Schmid
Thank you very much.
Can I do the same thing but only apply it to a single view? I want to keep the discipline as Electical, but make the Architectural features of the linked file darker.
CoreyDaun
One cannot control that per view. You would have to disable the halftone for all underlays, and that mark the Revit Link as halftone in each View through V/G.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
TJKawaguchi
An option is to create a separate sheet set and page set up replacing thin lines and printing black lines rather than gray scale.
