Show only
Search instead for
If this helped solve your issue - remember to 'accept as solution' to help other find answers! You can't think AutoCAD and run Revit. Email: LisaDragoEE@gmail.com
And a simple answer is yes. The families for duct fittings are pretty customizable, albeit sometimes with a little bit of work.
Corey D. ────────────────────────────────────────────────────────────────────── ⁞|⁞ Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
