Hi All,
I want to have my tags for mechanical equipment as below:
FCU-1, FCU-2, ... for my fancoil units
EF-1, EF-2, EF-3,... for exhaust fans
B-1,B-2,.... for biolers
and so on
I can use typr mark to address abriviations like FCU or EF in my tag but how can I have that number work?
If I use Mark to count then it doesnt start counting from one for new typr marks
and instead of above I get FCU-1, EF-2, FCU-3, B-4, FCU-5, EF-6 which I don't like.
Any thoughts?
Solved by CoreyDaun. Go to Solution.
It is not really the greatest method to use the Mark Parameter in this way. This is a special and unique Parameter that Revit uses to create a kind of ID, and you may not fully get the expected results, especially on a Worksharing-Enabled Project. It is recommended that another Shared Parameter (perhaps as a Project Parameter) be used for this as well. You can either search this board for a term like "Mark Parameter" or refer to >this thread< for more info on that.
Thanks Corey..it worked perfect for me...just need to add the numbers manually
a super stupid question....to assign that suffix I need to type it manually for each family type which can be very cumbersome... you mentioned there that it can be applied to all family types using the formula but I couldn't do that....Could you please clarify that to me plz?.. I tried putting B- in the formula but it is saying the following is not a parameter
Mehdi.Kardehi wrote:
"...a super stupid question....to assign that suffix I need to type it manually for each family type which can be very cumbersome... you mentioned there that it can be applied to all family types using the formula but I couldn't do that....Could you please clarify that to me plz?.. I tried putting B- in the formula but it is saying the following is not a parameter"
This is not in the slightest a stupid question! In order to enter a "defalt value" for a parameter in the 'Family Types' dialog, enter the value within quotation marks into the Formula field. (Without the quotation marks, Revit thinks that you are referring to a Parameter named "B-") Hit the Apply button, delete the text in the Formula Field. Done!
