Revit MEP
Valued Contributor
bvm76
Message 1 of 3 (202 Views)
Custom Pipe Size Tag
202 Views, 2 Replies
06-06-2014 03:09 AM
By default, my pipe tag is something like the one attached. I would like to get rid of the "mm" (40 mmØ = 40Ø).
Any helpful tips will be much appreciated.
Open the Family for editing. Select the Label element and click "Edit..." beside "Label" under Properties. Remove the "Size" Parameter and add "Diameter" instead, because you can customize the format of "Diameter" to remove the units by selecting it on the right side and then clicking "Edit Parameter's Units Format" (the button with the hand and # sign). In the next dialog, uncheck "Use Project Settings" and set "Unit Symbol:" to "None" and Click 'OK'. Now add the "Ø" character to "Suffix" for Diameter and hit 'OK'. Load it back into your Project, and opt to overwrite the previous version.
CADastrophe
Message 2 of 3 (190 Views)
Re: Custom Pipe Size Tag
06-06-2014 05:43 AM in reply to: bvm76
Valued Contributor
bvm76
Message 3 of 3 (114 Views)
06-09-2014 05:34 AM in reply to: CADastrophe
Great!
Thanks Corey.
