Revit MEP Forum
creating parallel conduits with fittings
3 REPLIES 3
seanrafferty808
635 Views, 3 Replies
When I create a conduit line with bends and fittings, the parallel conduit is just straight and does not apply the fittings to the new parallel line.
Any help is appreciated!
3 REPLIES 3
dennis
in reply to: seanrafferty808
Maybe it is the steps you need.  When you go to select the piece you want to offset, just highlight it and then hit the tab to walk down and get the the rest of the run, then select.
seanrafferty808
in reply to: dennis
It doesn't create the parallel fittings though. I thought maybe somebody knew if there was just no way to create those bends and curves with parallel conduit.
CoreyDaun
Could you post an image of you're situation? The steps dennis had described should produce parallel fittings under normal circumstances.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
