Revit MEP
New Member
0 Kudos
Post 1 of 3
Creating numbered text lists
565 Views, 2 Replies
09-26-2013 07:33 AM
I want to create a numbered text list (e.g. General Notes), but I want a space between each note.  How do I format the numbered list so that I don't have numbered spaces?
For example, when I highlight the text notes and click the icon to number the notes, I get:
1. (text note 1)
2.
3. (text note 2)
4.
5. (text note 3)
I really want this:
1. (text note 1)
2. (text note 2)
3. (text note 3)
This applies to Revit (at least the last three versions)...thanks.
61 Kudos
Post 2 of 3
Re: Creating numbered text lists
09-26-2013 12:24 PM in reply to: osu.sheltag
Revit's text editor leaves a lot to be desired, and you just found a prime example of that, unfortunately. It's currently not possible to add spaces like that in text boxes. I'm sure somebody knows a workaround, maybe using note blocks or a schedule.
1,007 Kudos
Post 3 of 3
09-27-2013 06:27 AM in reply to: osu.sheltag
Revit's text management is pitiful, at best. I refuse to use large blocks of Text in Revit primarily due to the erratic margins. I posted a thread about this long ago, but the issue still remains:
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Unstable-Text/m-p/3108892
Anyway, I have a solid work-around for this that employs a Generic Annotation Family and a Note Block Schedule. In lieu of running through the whole process, I am attaching an example Project (Revit 2012), which contains nothing by a Drafting View (for placement/management of the Generic Annotations) and a Sheet View with two Note Block Schedules.
If you have any questions, please don't hesitate to ask!
