Revit MEP
Valued Contributor
RJK42
Message 1 of 2 (1,461 Views)
Accepted Solution
Creating new sub-disciplines
1461 Views, 1 Replies
01-14-2013 05:41 PM
How do I create a sub-discipline?? I drew up just a basic 2D representation of mechanical equipment, duct, and one-lines for piping in AutoCAD.  Then I took the AutoCAD file and imported it into a floor layout in revit.  I would like to make a sub discipline under Mechanical, and another under Plumbing.
Thanks!!!
The "Sub-Discipline" Parameter is merely a Project Parameter (Instance/Text) that applies to all Views. If the parameter is not present, go to Manage Tab » Project Parameters and add it. Once the parameter is there again, you can manually input whatever value you want to create a new Sub-Discipline - that pull-down is just a quick way to select a value that already exist in the project.
If you see the Parameter under the Views' Properties, but it does not show up in the Project Browser, then you may need to adjust it. Go to View tab » User Interface ▼ Browser Organization.
*Expert Elite*
CADastrophe
Message 2 of 2 (1,440 Views)
Re: Creating new sub-disciplines
01-15-2013 05:34 AM in reply to: RJK42
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
