Hi!
I would like to create a plumbing riser tag. I am not sure what catagory to use or what type of tag I should use.
Any suggestions are welcome.
Thanks 😄
@sforsberg215 wrote:Hi!
I would like to create a plumbing riser tag. I am not sure what category to use or what type of tag I should use.
Thanks 😄
It depends on the category your going to tag. EVERYTHING is based off a category. If your going to tag a pipe riser, than you would use pipe tag. If you have a cap on the top you would use pipe accessory/fitting tag depending on what the family/system family is categorized under..Etc.
