Revit MEP
Active Contributor
sforsberg215
Message 1 of 3 (201 Views)
Create Tags for No catagory
201 Views, 2 Replies
07-21-2011 06:43 AM
Hi!
I would like to create a plumbing riser tag. I am not sure what catagory to use or what type of tag I should use.
Any suggestions are welcome.
Thanks :smileyvery-happy:
CADastrophe
Message 2 of 3 (193 Views)
Re: Create Tags for No catagory
07-21-2011 07:36 AM in reply to: sforsberg215
What version of Revit are you using?
Distinguished Mentor
Jrobker
Message 3 of 3 (187 Views)
Re: Create Tags for No category
07-21-2011 09:53 AM in reply to: sforsberg215
sforsberg215 wrote:
Hi!
I would like to create a plumbing riser tag. I am not sure what category to use or what type of tag I should use.
It depends on the category your going to tag. EVERYTHING is based off a category. If your going to tag a pipe riser, than you would use pipe tag. If you have a cap on the top you would use pipe accessory/fitting tag depending on what the family/system family is categorized under..Etc.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
