Revit MEP Forum
Create Tags for No catagory
2 REPLIES 2
sforsberg215
375 Views, 2 Replies
Hi!
I would like to create a plumbing riser tag. I am not sure what catagory to use or what type of tag I should use.
Any suggestions are welcome.
Thanks 😄
2 REPLIES 2
CoreyDaun
in reply to: sforsberg215
What version of Revit are you using?
Jrobker
@sforsberg215 wrote:
Hi!
I would like to create a plumbing riser tag. I am not sure what category to use or what type of tag I should use.
Thanks 😄
It depends on the category your going to tag. EVERYTHING is based off a category. If your going to tag a pipe riser, than you would use pipe tag. If you have a cap on the top you would use pipe accessory/fitting tag depending on what the family/system family is categorized under..Etc.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
