I created a custom panel schedule template. All of a sudden, whenever I try to insert the schedule onto a sheet, Revit reports a serious error has occurred and crashes. I tried to transfer it to another project but it still crashed. Has anyone else encountered this?
I had that once before when I started to mess around with the total loads. I removed one and then tried adding it again and then when I tried to use the template all I got was about 15% of a schedule and it occasionally crashed.
What elements did you change in the schedule?
I changed quite a few. But just now I removed all parameters from the entire schedule except for the load values and it still insisted on crashing.
