Revit MEP
Active Member
dworakma
Message 1 of 3 (242 Views)
Copy/Monitor - Type Mapping Tracking flows
242 Views, 2 Replies
09-26-2012 10:45 AM
Working on a project where another firm is modeling the fan coil units and we're hooking up the piping.  I was hoping I'd be able to copy/monitor each piece using the "type mapping" behavior.  However, it doesn’t seem to pick up on a change of flow (i.e. 5 GPM to 10 GPM) using the coordination review.
Am I too hopeful?
Thanks in advance.
I believe that you are, unfortunately. Copy/Monitor simply creates a copy of the element and creates an association, but does not convey any of the design information from the linked project. Some of the Parameter Values will be translated when the Copy/Monitor first occurs, but if changed in the Linked Project, it won't translate those updated values on to your elements.
You can Tag the elements through the Linked Project or Schedule them to get a current reading on their values to compare to yours.
CADastrophe
Message 2 of 3 (241 Views)
Re: Copy/Monitor - Type Mapping Tracking flows
09-26-2012 10:55 AM in reply to: dworakma
Valued Mentor
julianjameson8403
Message 3 of 3 (230 Views)
09-26-2012 12:39 PM in reply to: dworakma
Try a Mechanical Equipment Schedule showing your equipmennt and the equipment in the linked model shown with relevant parameters displayed
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
