Is it possible for user at the main corporate offices to connect to the central server running in that office? We are being told that we must have a local server running that the users connect to but the installation indicates users can connect to the central server.
You are rigth, if you are all working from the same office you don't need to set up the local servers. The Central Server can function as "local server" (in this case).
Hello Fer
We have installed AutoDesk Revit Server 2013 in Central Server(Windows 2008 R2 Standard) and the Local Server (Windows 2008 R2 Standard) .
How to configure Central Server and Local Server for use with multiple offices over a WAN?
Please infom me Which is the Environment Varible value of following 3
1.Central Server
2.Local Server
3.Host
I know that environment variable is RSROLE2013 . Which is the value ? Is it Host,Accelerator,Admin for Central Server Environment Varible value.
Our issue is revit model not synchronizing from Local to Central Server.
Its only Synchronizing from Host to Local Server.
How do we resolve this issue?
