Revit MEP Forum
connect warning
2 REPLIES 2
GHASEM_ARIYANI
354 Views, 2 Replies
connect warning
hi
When I connect the power to the water heater The following warning is displayed.What settings should I do?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
It appears that you are trying to connect a 1-pole or 3-pole piece of equipment to a 2-pole Electrical Circuit. If the equipment is intended to be 2-pole, then check the element's Properties and Type Properties for a parameter that controls the Number of Poles. If you cannot find one, you will have to open the Family for editing and select the Electrical Connector to see what the Number of Poles is set to.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi CADastrophe
Thank you.
You are right  .
