I'm trying to connect sanitary, I'm select on toilet, then I see sanitary connection's junction I select it, and see mesage "no auto-route solution was found", like in this pictures. Could you say my mistale? (first day of using revit ;])
The waste line needs to drop from the waste connection on the bottom of the fixture and turn latterlay with enough room for a wide sweep elbow.
Make sure your lateral run is far enough below the floor....So change your offset to further below the floor.
