Non slope pipes:
I need to connect/combine two pipes into one with different offsets/elevations. I know which pipe offset I want
so I copy paste that offset to the other pipes properties then connect them together(drag connector to connector).
Is there a shorter way?
Sloped pipes:
I would cut a section then use the Align tool.....There must be a shorter way?
A small way to speed things up slightly would be to use the Offset Pulldown list, which may not work that well if there are a billion different Offsets Heights in the Project. You could also Copy/Paste the desired height into the Offset Field in lieu of to the Properties Palette.
