Is it possible to use conditional formatting in Panel Schedules?
For example I created a project parameter that displays in the panel schedule that I would like to show up red if another value is greater than 0.
Is this possible in panel schedules? or only in normal schedules...
Solved by CoreyDaun. Go to Solution.
Conditional Formatting is only available in normal Schedules. Create an Electrical Circuit Schedule, grouped by Panel Name, sorted by Circuit Number, and then set your Conditional Formatting.
Unfortunately you cannot add conditions for Panel Schedule. You can change the cell shading by editing the template manually but it will affect all Panels' schedule that are using the modified template.
The best way is to send wishlist request to Autodesk Development team
Here is a link for that
