Hi Guys,
Whats the simplest way to create equipment cioncrete bases please?
I tried doing a thick floor but that doesn't come out too well as you can see the lines though the plant.
I'm sure there must be a simple way to do this but can't find anything in the Famillies or elsewhere.
Paul
Solved by bit000. Go to Solution.
hi paul,
i cound not understand clearly....
i think you need to create family place on concrete base (plinth) /
1 before creating family you need to choose the family template (floor, wall, celling ect..)
2 family placed on the floor or concrete select Metric Mechanical Equipment.rft / Metric Generic Model.rft family template.
3 family category and parameters/ mechanical requirement/ work plane-based (Check box yes) OR family category and parameters/ Generic Model / work plane-based (Check box yes)
add your family to your project
i hope this can solve your problem.
Thanks for getting back to me but I guess I didn't make myself clear.
I want to be able to create a plinth for things to sit on. The plinth can vary in size and height.
Sometimes I'll just have a plinth with nothing on it.
I thought there might be a Familly Plinth but couldn't find one.
Does tbis help?
Paul
hi paul find the attachment,
go to the family category and parameters find the exact family category
