Revit MEP Forum
Concrete Plant Bases
4 REPLIES 4
1168 Views, 4 Replies
Hi Guys,
Whats the simplest way to create equipment cioncrete bases please?
I tried doing a thick floor but that doesn't come out too well as you can see the lines though the plant.
I'm sure there must be a simple way to do this but can't find anything in the Famillies or elsewhere.
Paul
4 REPLIES 4
bit000
hi paul,
i cound not understand clearly....
i think you need to create family place on concrete base (plinth) /
1 before creating family you need to choose the family template (floor, wall, celling ect..)
2 family placed on the floor or concrete select Metric Mechanical Equipment.rft / Metric Generic Model.rft  family template.
3 family category and parameters/ mechanical requirement/ work plane-based (Check box yes) OR family category and parameters/ Generic Model / work plane-based (Check box yes)
add your family to your project
i hope this can solve your problem.
regards,
bit
in reply to: bit000
Thanks for getting back to me but I guess I didn't make myself clear.
I want to be able to create a plinth for things to sit on.  The plinth can vary in size and height.
Sometimes I'll just have a plinth with nothing on it.
I thought there might be a Familly Plinth but couldn't find one.
Does tbis help?
Paul
bit000
hi paul find the attachment,
go to the family category and parameters find the exact family category
regards,
bit
in reply to: bit000
Perfect thanks so much!
