Hi, I have an instalation problem. I wan´t to install Revit 2015 for students.
I make the download of a .exe file, I execute as administrator this file, it opens the Revit setup and I start the instalation. After that, when finished all of the items of the instalation is missing. After that I try to execute the .exe file again and appear the warning on the attachment.
I hope I can get your help
Thank you
Hi @filipesmsantos,
The "Communication Failure" error typically occurs during the Install Now method for downloading and installing Autodesk software. The most common solution is to use an alternate download method. Try this Autodesk Solution for the complete steps on how to resolve this error. If you have any other questions please reply to this post. Thanks!
