Revit MEP Forum
Color Fill Legend for Conduit
2 REPLIES 2
GHASEM_ARIYANI
1840 Views, 2 Replies
hi
For Conduit We also like the pipe assigned Color Fill Legend?
For example, I need to set the color by Service Type.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
abulla
in reply to: GHASEM_ARIYANI
What you want to do in this case is create different types of conduit using Duplicate from the type properties menu. Then, you can either create a parameter for Service Type, or use one of the existing parameters like Type Comments to fill in the service type. Finally, you need to set up a filter for conduits that looks at the service type parameter you're using, and you can assign a solid color surface pattern to that. I don't believe there is a color fill legend for conduit yet though.
GHASEM_ARIYANI
in reply to: abulla
hi
Hi and thanks abulla.
I enjoyed very much for your answer.
