Hi guys,
I'm trying to create a "collector" which is a mechanical equipment which collects water from multiple branches (something like on the picture)
but I can't find the right approach. I don't know what type of template for this element should be used and how to correctly set input and output connectors. I try to create mechanical equipment but system inspector can not recognize it so the flow inside the connector can not be calculated. Any hint?
Thank you.
Rudolf
The inputs shall have a parameter associated with each one. The "In" flows should be something like "IN 1", "IN 2".... The output should have a parameter, but associate a formula with the value, such as "OUT 1 = IN 1+ IN 2 + IN 3". The IN's should be set to calculated and the OUT should be preset.
Good Luck!
Hi.
I need one collector and your seems to be a very good one.
Can I borrow yours?
Cheers
