I am an electrical engineer working for an MEP firm and we are beginning to circuit everything everything in Revit rather than making panel schedules in Excel. We have it figured out for the most part, the problem we are running into is circuiting mechanical equipment. The idea that we came up with is to place a junction box that we could change the voltage and load on wherever the mechanical equipment is. This seems to work but what we would like to do is create some type of "no plot" filter for these junction boxes so that when it is time to plot the drawings these junction boxes do not show and cause confusion. Anyone have any suggestions on how to do this or better suggestions on how to circuit the mechanical equipment? Thanks in advance for the help!
P.S. We are using Revit 2014.
Solved by abulla. Go to Solution.
We've found a solution similar to your idea, except we use an electrical connection symbol with no visible 3d geometry, then we circuit that rather than trying to circuit the mechanical equipment directly. It calls for one more level of coordination, but at least our circuits won't break when the mechanical guys inevitably change their equipment selections.
That looks like a great idea. Where did you find the electrical connection? I'm assuming when you place it you're able to change the load in the properties?
I made it . All I did was take the out of the box Junction Box and make the geometry not visible, changed the symbol from the J-box to the equipment connection, then made the load an instance parameter.
