Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Circuiting for power & Lighting on same DB board
1 REPLY 1
377 Views, 1 Reply
Hi All,
Is there any possbilites to distribute power and lighting on same DB board?
For an example, when I start to do power outlet circuiting like EDB-P01,EDB-P02,EDB-P03......(EDB=DB Name).Now when I start to allocate lighting fixture on same board it should start from EDB-L01,EDB-L02....instead of picking next number like if I allocated 3 power outlet on DB board then for lighting it shouldn't pick EDB-L04..I want lighting still as EDB-L01..
Is that possible??
1 REPLY 1
CoreyDaun
I don't believe that this can be achieved. Revit's Circuit Numbers are continuous and cannot be changed; you would have to use a Shared Parameter and rely on manual entry for each custom Circuit Number.
So, you do not number the circuits on your panel schedule sequentially for the entire panel? Can you post an image of an example panel schedule with mixed power/lighting circuits?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
