I am doing electrical circuiting but I cannot get the correct number for the circuit number (circuit number jump from 2 to 4 - see attached). Circuit number 4 should be 3.
Many thanks in advance.
Solved by bvm76. Go to Solution.
how'd you fix it - by moving the circuit in the panel schedule? Interested to see what you did, we're not using the same circuit naming system, so Id be interested in learning what you did -
thanks - David B.
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
got it - the old pesky "where the heck did that come from" error...I get that a lot -
Have a Happy New Year! db
David A. Butts
