Is it possible to customeise the circuit naming into 1-L1, 1-L2, 1-L3, 2-L1..... where L1, L2, L3 are the Phase A, B, C lables?
Curently, revit can only have L1-1, L2-1, L3-1 as circuit name if you set the circui naming into "By phase".
Where do you want to see your circuit naming as 1-L1?
is it in the system browser, panel template or schedule
I thought i was able to create a calculted value with the IF condition formula but i just realised, i can't evaluate a text parameter in an IF statement
i thought of doing something like IF (ciruit number = L1-1, "1-L1")
but it will be long and it doesnt even work
sometime is better to adapt to things instead of changing it
if you want to have this as a wishlist then you could fillup this
