I have a couple of hundred 16dia pipes on a certain pipe system that I want size to change in one go, is this possible? a schedule doesnt seem to allow me to select/change the size?
Solved by abulla. Go to Solution.
I believe you can change pipe sizes all at once by using the "Diameter" parameter in your schedule rather than "Size".
