Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Change Zone In Space Schedule
2 REPLIES 2
gurselgunacar
531 Views, 2 Replies
I wonder is there any way to change zone of spaces in space schedule? It is hard to find in plan with add zone selection.
https://www.bilgitara.com
2 REPLIES 2
salah_2015
in reply to: gurselgunacar
You can only highlight the selected space in the view it is in.
If my answer solved your problem , Please Kudo  and Accept as solution.
simon.locke
Hi there,
You can highlight the zones and spaces in the view using the system browser. Goto View tab - User Interface - System Browser.  Once it's open select 'Zones' from the view drop down at the top.  You can't change the zone the space is in from here but you can highlight the zones to edit them and then highlight the spaces live in the view you're in prior to selecting in the view to remove therm from the current zone.  This may help.
BIM Consultant at Graitec Ltd
Feel free to like or accept solutions as long as it is a solution or as a minimum, useful!
