I am Electrical Engineer trying to set up templates and content for our electrical design team. I am partticularly interested in setting up all electrical settings including wires, families, panel schedules, legends and so on.
I found impossible to change the apperance of "Wire Size" column after adding it as a new colum in the "One column" Panel configuration inside panel family.
I would like to change the "#" symbol into "x" and add 'mm' so that the size of the cable could be visible according to my company standards, for example (1x1.5mm, 1x1.5mm, 1x1,5mm).
Therefore, it appear that the only posiible way to present Wire Size in Revit is something like: (1-#1.5, 1-#1.5, 1-#1.5).
Please help and let me know of any advices.
Thank you.
Hello and welcome to the Discussion Groups!
I don't believe that this is possible (as of Revit 2014). Below is a link that is frequently provided by Autodesk Support personnel that visit these forums. Use this to provide them with feedback about this issue.
Autodesk Product SupportThe following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
