Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
change order of tabs ribbon tabs in Revit one box
7 REPLIES 7
Message 1 of 8
dtiemeyer
1793 Views, 7 Replies
Using Revit one box, we are predominantly MEP engineers, but I want the other ribbons to remain available to the users. But I would also like the 'Systems' tab to be leftmost. Is this possible?
I don't see any mechanism for organizing the tabs in the 'User Interface' portion of Options.
Any suggestions?
My other CAD is a Cadillac and I like to Revit to the Max!
7 REPLIES 7
Message 2 of 8
CoreyDaun
in reply to: dtiemeyer
While holding CTRL, click and drag the Ribbon Tabs to where you'd like them.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 8
dtiemeyer
in reply to: CoreyDaun
Thanks Corey!
That works, but it doesn't look like that settings is being saved in Revit.ini.  I'm wondering where it's saved and how I can push it out to the masses. Any thoughts?
Message 4 of 8
CoreyDaun
That, I don't know. Search this forum and the Revit Architecture forum and see if anyone else has ever posted a solution.
Message 5 of 8
Lance.Coffey
Here is an old document regarding resetting the Revit interface:
Resetting the Autodesk Revit 2012 user interface
http://usa.autodesk.com/getdoc/id=TS16825244
In this document it indicates that the Ribbon and Quick Access Toolbar information is stored in the UIState.dat file.
Lance Coffey
Technical Support Specialist
Message 6 of 8
dtiemeyer
in reply to: Lance.Coffey
Thanks, but when I put my 'UIState.dat' file onto a different computer, it caused Revit to go into 'Viewer Only' mode. So even if this file does control the sequence of the tabs (which it appears to), it would seem there is no good way to share it to my other 80 users. Is that correct?
Dustin
Message 7 of 8
Lance.Coffey
I wouldn't expect the UIState.dat file to put Revit into a viewer mode. However, there is normally a shortcut on the start menu to start the Revit viewer.
How did you launch Revit after changing the UIState.dat file?
Lance Coffey
Message 8 of 8
dtiemeyer
>From the same desktop icon that I had started it with previously. And just to be clear, this was a UIState.dat file created on a different PC. It's not that big of deal, if there is no 'officially supported' way to do it, I'll just teach my users how to make the change.
Dustin
Rail Community
