Revit MEP Forum
Change name of shared parameter in txt file?
5 REPLIES 5
cadmancan
591 Views, 5 Replies
Starting brand new project.  Would like to change the name of some shared parameters within my txt file.  As far as I know you cant chnage the name once its established witin Revit (unless theres a third party app).  Would there be any issue withi this?  Utimately I am pushing these parameters into new geometry and I would like them to better conform to a standard for a particular customer.  I rennamed JUST the parameter name and it seemed to work ok.  I know this isnt the most ideal but I would rather not re-create several shared parameters.  Any thoughts?  Thanks.
5 REPLIES 5
lrtuss
in reply to: cadmancan
Any family that had the parameter in it will not work with the new spelling. Tends to make Revit crash.
cadmancan
in reply to: lrtuss
But if I havent pushed the parameters into any families yet, it would be ok?  Thanks.
CoreyDaun
It will use the same ID, so you can't use in anywhere where the previously named Shared Parameter exists. As long as you haven't used the Shared Parameters anywhere, it should be fine. Otherwise, I would recommend recreating the parameters. I've gone through that twice, now, in radically reforming a few of our techniques.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Tags (1)
thecadmancan
in reply to: CoreyDaun
Thank you for your input.  That helps alot
adam.jw
in reply to: thecadmancan
Try this handy little tool out (free):
http://openrevit.com/2011/08/spwriter-v020/
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
Rail Community
