Revit MEP Forum
Chamfer corners aren't perfectly round
2 REPLIES 2
321 Views, 2 Replies
This formula is good by itself as a dimension calculator
1.17 * sqrt(Designed Air Flow / 1.75 m/s)
but when I do this
round(1.17 * sqrt(Designed Air Flow / 1.75 m/s))
I get inconsistent units error!!
any thoughts?
M
2 REPLIES 2
CoreyDaun
The ROUND functions only work with unitless Number values, so you cannot directly round Air Velocity, Angle, or Length Parameters to name a few. The trick here is to strip the units before the ROUND function and then reapply the units at the end of the formula. Silly, I know...
= round((1.17 Hz * sqrt(Designed Air Flow / 1.75 m/s)) / 1 m/s) * 1 m/s
A simpler example of this would be:
= round(Length / 2)  (yields an error)
becomes
= round((Length / 2) / 1 mm) * 1 mm
(or you could just add the units to the "/2")
= round(Length / 2 mm) * 1 mm
in reply to: CoreyDaun
Thanks mate...I like the unit consitency check in Revit but in this case...it's just silly as you said;)
