Revit MEP
Distinguished Contributor
Mehdi.Kardehi
Message 1 of 3 (148 Views)
Chamfer corners aren't perfectly round
148 Views, 2 Replies
04-13-2014 11:26 PM
This formula is good by itself as a dimension calculator
1.17 * sqrt(Designed Air Flow / 1.75 m/s)
but when I do this
round(1.17 * sqrt(Designed Air Flow / 1.75 m/s))
I get inconsistent units error!!
any thoughts?
M
The ROUND functions only work with unitless Number values, so you cannot directly round Air Velocity, Angle, or Length Parameters to name a few. The trick here is to strip the units before the ROUND function and then reapply the units at the end of the formula. Silly, I know...
= round((1.17 Hz * sqrt(Designed Air Flow / 1.75 m/s)) / 1 m/s) * 1 m/s
A simpler example of this would be:
= round(Length / 2)  (yields an error)
becomes
= round((Length / 2) / 1 mm) * 1 mm
(or you could just add the units to the "/2")
= round(Length / 2 mm) * 1 mm
CADastrophe
Message 2 of 3 (124 Views)
Re: Chamfer corners aren't perfectly round
04-14-2014 05:29 AM in reply to: Mehdi.Kardehi
becomes
Mehdi.Kardehi
Message 3 of 3 (106 Views)
04-14-2014 05:54 PM in reply to: CADastrophe
Thanks mate...I like the unit consitency check in Revit but in this case...it's just silly as you said:smileywink:
