So here is my problem. I have insterted muliple points on a floor plan for layout in the field using a Trimble Robotic Total Station. Those points, are modeled to look like Hilti Sleeves. These sleeves range in size from 6 to 2 inches. They are for pipes to go through. after the concrete flooring is poured. there is a Diameter box in the dimensions section on the properties pallet. but i can not insert that to show up on the pipe accessory schedule. How would I go about editing this family to make the size of sleeve show up on a schedule? I have attached the family in hopes that I can get some advice on how to make this happen. I have already added the second size parameter...that did not work so well for me.
For a parameter to be available to be scheduled it has to be a "shared parameter".
Louis
Please mention Revit version, especially when uploading Revit files.
Yes,
that is definately a step in the right direction. How would one go about adding a formula in that particular parameter to take information from the diameter parameter that is already associated with that fmaily? Or would one just manipulate the existing parameter?
- Bil
You can modify an existing parameter and replace it with another one. So you can replace the family parameter with a shared one. Take note that they both a have to be of the same type (e.g. you can not replace a number type parameter with an integer type parameter)
Louis
