Revit MEP Forum
Centerlines show has Hidden lines
3 REPLIES 3
SLDBrown
2316 Views, 3 Replies
Hello All,
I have ductwork under a slab. The linework shows as hidden because the "cut plane" bottom is set at 0 and the view depth is set at -5. That part shows correctly. My problem is, the centerline on the pipe under the slab shows as hidden. How do I make this a centerline? Where do I go to adjust the linetype?
Thanks in advance,
Steve
3 REPLIES 3
thombrady
in reply to: SLDBrown
I believe you can change this in visibility graphics, expand the pipe tab & it will say centerline. Hilight it & change it to centerline. I just tried it & it worked, I am a contractor who shows the insulation so I typically keep centerline off. Good luck
CoreyDaun
What version of Revit are you using? As far as I recall, the MEP Hidden Lines are only drawn when MEP elements are overlapping. In other words, I don't think that the slab would cause the MEP Hidden Lines to be drawn. Instead, I think that you are seeing the "Beyond" Lines that are created by your View Range settings.
In either case, I don't believe that there is much that can be done to change the Centerline without changing the appearance of the rest of the Duct lines. This is because MEP Hidden Lines and the application of the Beyond Lines has a higher priority than the V/G Overrides. You can customize the Line Pattern of the MEP Hidden Line and Beyond Line Styles (under Manage tab » Additional Settings ▼ Line Styles), but this would affect ALL of the applicable lines, not just the Centerline.
In essence, I do not believe that you can get what you are after, but if you alter your View Range settings so that the "Bottom" is also set to -5, then you will escape the "Beyond" Line Style. Even then, I don't think you'd be able to apply a hidden line appearance to the Duct without also making the Centerline appear that way, as well.
SLDBrown
in reply to: CoreyDaun
You are correct in regards to the "beyond lines". I thought that what I wanted to do wasn't possible but I thought I would ask. Also, I discovered that the centerline (showing as hidden line) I was seeing was a graphics glitch. It went away when I published the sheet. Thanks so much for your reply.
Rail Community
