Revit MEP Forum
ceiling not hiding when in hidden mode 3d view
2 REPLIES 2
pverduzco
550 Views, 2 Replies
In Revit MEP 2014 I set a 3d iso view looking down at an area and the ceiling is transparent even in hidden mode.Is there a setting I can change so that the ceiling hides in hidden mode like all the other object? For example I am looking down on the roof and all the ceilings are visible in hidden mode.
Makes it very confusing visually.
See pic for visual description of problem.
2 REPLIES 2
CoreyDaun
in reply to: pverduzco
Can you post a sample Project file?
pverduzco
in reply to: CoreyDaun
Corey
Thanks for your response, this project is the plumbing model with several links attached to it. ie. structural, architects and equipment. I believe I m not able post the entire project. I am checking with our program specialist. I am going to check the archs link and see if the issue is present there.
Thanks Again.
