Hello!
I have to finish an apartment model which is symmetric in many aspects. Hence, I tried using 'Mirror/Copy' command on my electric circuits to ease the process. The problem is that even though it does copy all the electrical/lighting fixtures, switches & equipments; the circuit connections which I made (i.e. receptacles to panels, lighting fixtures to switches, etc.), do not get copied.
So is there any other alternative to solve this problem or will I have to make all the circuit connections of 12 flats on every floor of a 15 floor building, manually?
Kindly reply!
Go to properties and check the level, offset, view range as well as workset and visibility.
