I do not know waht you exactly expect from that template but basically a template is a revit project saved as a template.
So if you bring everything in a project you need (load/copying etc) and then do save as template and you are on your way.
Louis
Please mention Revit version, especially when uploading Revit files.
thankyou bvm76
but where can i find transferring project template menu ?
go to manage tab then click transfer project standard (see attached image). If you want to save the default electrical template as your drawing template, then copy the standard properties from default mechaical template. You can choose what properties you want to copy by tick/untick the box to the left.
