Revit MEP Forum
Can't select objects
2 REPLIES 2
1013 Views, 2 Replies
I want to mirror a wall. I click on modify then select my wall using a crossing window. It will not select the wall so I can get the modify options. If I use a left to right or right to left it does not matter, it will not select it. If I double click on the wall it works fine and the modify options show up. This is ok when only needing to modify one object, but I can;t see having to double click a hundred times to add multiple objects to my selection set.
Anyone have any thougths why my crossing windows will not select the wall. Yes, I know how to use crossing windows and am doing it correctly. Is there a setting or a varible that needs tweaking?
Thank you for your replies
2 REPLIES 2
Jrobker
Change your discipline to Architectural in the view properties.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
Thank you
