Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Can't see lower floor
4 REPLIES 4
meaton224
753 Views, 4 Replies
I am trying to have the lower floor show on my first floor plan.  I have changed my underlay to the lower floor but the architectural walls are not showning.
I need to have the electric room on the lower floor show on my site plan which has the first floor as the associated level.  Any ideas?
Thanks!
4 REPLIES 4
in reply to: meaton224
You also should check your View Rannge to see if it goes below the current level.
Mike
meaton224
I have changed my view range several times to see if that did it and it is still not showing.
CoreyDaun
Hello, and welcome to the Discussion Groups!
Would you be able to supply a sample of your Project file for investigation? If you would like, you could send it to me via email and I will look into this. Send me a Private Message and I will send you my email address as a reply.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
meaton224
in reply to: CoreyDaun
I think I am all set.  I made another view with the lower level as my associated plan and put in a detail line for the room I needed on the first floor.  Thanks for your help!
