Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Can't Hide in View
14 REPLIES 14
Message 1 of 15
cdeweese
18946 Views, 14 Replies
Can't Hide in View
When I go to View -> Hide in View ->
the Elements and Catagory are grayed out. Does anyone know why? Something probably simple but can't figure it out.
Chris
14 REPLIES 14
Message 2 of 15
jason.martin
in reply to: cdeweese
Nothing is selected, so there is no category or element to hide?
(guessing?)
jason
"cdeweese" wrote in message news:5918340@discussion.autodesk.com...
> Thanks,
> Chris
Message 3 of 15
cdeweese
Well, I'm trying to hide different elements that are on the linked model. I select the linked model as a whole and element is NOT grayed out but when I tab thru to select different elements and not the whole model it is grayed out.
Message 4 of 15
jason.martin
Hi Chris -
I tried this in 2008 and 2009, and in both cases got it to work, but I think
I figured out what the problem might be.
If you have your view configured so that the link is displaying with a view
definition from the "link" rather than by host view, the options to override
the view settings for the items in the link "locally" (i.e. hide specific
elements or categories in this view) becomes disabled, because you're
telling the application to use a specific set of view settings defined in
the linked file, rather than the view settings defined in the "host" view.
You can still override the visibility of things that are in the "local"
project, but you've told the link to display exactly as it is displayed in
the linked file, and it's going to display that way (which is why you can't
override it).
hth
jason
"cdeweese" wrote in message news:5918363@discussion.autodesk.com...
> grayed out.
Message 5 of 15
cdeweese
That is correct in VG I have the linked view: Floor Plan Level 1 that way the room names are visible. I changed it back to none and tried it and it worked. I guess I want the best of both worlds. Thanks man.
Chris
Message 6 of 15
agutierrez
in reply to: jason.martin
OMG!!!!! I have been trying to figure that out for years!!! That just made my week, this has bothered me and I have had to do so many things to get around that.. Even to the point of going into other models and deleting the objects!. Thank you so much
Message 7 of 15
lbirdsall
I am having a similar problem. I am able to hide by category in other views but it's not an option in when I'm in 1 particular view.
Thank you,
Lynda
Message 8 of 15
m.voss.alvine
in reply to: lbirdsall
do you have a view template set?
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Message 9 of 15
lbirdsall
in reply to: m.voss.alvine
I believe I was trying to hide things that appear on a schedule? Could that be the problem?
Thank you,
Lynda
Message 10 of 15
fabiosato
The only way I know to remove items only from a schedule is through filters.
Fábio Sato
Message 11 of 15
MAXDesign_01
I had the same problem. Somehow I changed my view the plate from "none" to "Architectural Plan." When it was using the Architectural Plan template I could not hide any imported CAD lines. Then I changed it back to none and I was able to hide CAD lines. So click on the view and see what view template it is using in the properties dialog box.
Message 12 of 15
taylorBUVBW
What exactly should our VV be prompted to ? I tried to make sure my link was local and not custom but I still think I am doing something wrong.
Thank you
Message 13 of 15
s.borello
Are you trying to hide something in a link?  If your views are set to a linked view it can mess with you.
Message 14 of 15
Dronov.Dmitry
Якщо створити новий вигляд і не накладати шаблон - елеметни лінкованого файла можуть бути сховані.Як тількі накласти шаблон - ця можливість втрачається і навіть якщо шаблон зняти - елемент не можна знову ховатиТреба зробити новий 3D вигляд і не накладати шаблон
If you create a new look and do not overlay a template - items of link file can be hidden.
As soon as you apply a template - this opportunity is lost and even if you remove the template - the item can not be hidden again
It is necessary to make a new 3D look and not to impose a template
Message 15 of 15
stephensmandac
In Identity Data
Click View Template
Choose "None"
