Solved by cdeweese. Go to Solution.
Solved by jason.martin. Go to Solution.
OMG!!!!! I have been trying to figure that out for years!!! That just made my week, this has bothered me and I have had to do so many things to get around that.. Even to the point of going into other models and deleting the objects!. Thank you so much
I am having a similar problem. I am able to hide by category in other views but it's not an option in when I'm in 1 particular view.
Thank you,
Lynda
do you have a view template set?
The only way I know to remove items only from a schedule is through filters.
Fábio Sato
I had the same problem. Somehow I changed my view the plate from "none" to "Architectural Plan." When it was using the Architectural Plan template I could not hide any imported CAD lines. Then I changed it back to none and I was able to hide CAD lines. So click on the view and see what view template it is using in the properties dialog box.
What exactly should our VV be prompted to ? I tried to make sure my link was local and not custom but I still think I am doing something wrong.
Thank you
Якщо створити новий вигляд і не накладати шаблон - елеметни лінкованого файла можуть бути сховані.Як тількі накласти шаблон - ця можливість втрачається і навіть якщо шаблон зняти - елемент не можна знову ховатиТреба зробити новий 3D вигляд і не накладати шаблон
If you create a new look and do not overlay a template - items of link file can be hidden.
As soon as you apply a template - this opportunity is lost and even if you remove the template - the item can not be hidden again
It is necessary to make a new 3D look and not to impose a template
