Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Can't find or fix error ID's
6 REPLIES 6
ceaves
1069 Views, 6 Replies
I've attached a copy of the errors and problems i'm having.
6 REPLIES 6
ceaves
in reply to: ceaves
I forgot to attach this info file.
adam.jw
in reply to: ceaves
How about a quick explaination in the OP so we can get a better idea of what's going wrong first, before we start opening attachments?
That way when other people use Google or the forum search to find answers to a similar problem they'll be able to find it more easily in the future.
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
ceaves
in reply to: adam.jw
I don't have much experience with Revit or forums and I don't know what you mean by "quick explaination in the OP".
adam.jw
in reply to: ceaves
Summarize what you were trying to do, and what went wrong, in your original post (OP). That'll help people searching the forums find this post.
You can edit posts by clicking on the "options" link and selecting "edit"
ceaves
I can't find the "edit" under "options" so all I know to do is to reply to this.
When I try to load my family into the .rfa file I get errors that show element ID #'s. When I go back and open the .rfa file and search for the element ID #'s I get a window that says "The following Element ID #'s are invalid and won't be used: # #. I search for those ID's but can't find them anywhere.
CoreyDaun
in reply to: ceaves
Many (but not all) of the Types defined by the Type Catalog create errors with the Family's constraints. Open the Family (or a copy of it) and manually enter the values of one of the erroneous Type (list attached) to see which dimensions/constraints are being broken. Note that I cannot guarantee that is it the same constraint that is being broken for all of the erroneous Types.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
